I have four 285-30-20 PSS on my car's stock rims.
They work fine; handle about equivalent to stock Dunlops. At Road America track day last month with passengers went a best lap 2:33.5 but there was traffic; Traqmate's Theoretical Best Lap was 2:30, but I think it could have gone a bit better.
The stock summer Dunlops got me a 2:29 actual and 2:29 TBL.
The winter (allseason) Dunlops were good too, got a 2:30 out of those
and they wear like IRON, but of course these are different days/weather/traffic etc.
I did not think square setup understeered significantly less than with stock / size tires; the PSS push and howl a little at/beyond their limits, while stock tires tended to quietly understeer with the occasionally mentioned "juddering" of front tires across pavement.
I got the impression that the PSS might be SLIGHTLY less tolerant of overheating, as they seemed to go away a bit more than the Dunlops toward end of session or when pushed to max awhile; could be the PSS lesser mass heats up more quickly/to higher temp spike than the more massive stock Dunlops, and so acts that way.
I have suspected the reason the Dunlop "all season" winter tire package tires did almost as well as the summer Dunlops could be that the harder/longer wearing tread compound of the winter tires heats up and gets soft slower than the soft summer Dunlops...so maybe the softer summer tires work better the first 2-3 laps, but the winter tires heat up and eventually do better toward end of sessions once their harder tread heats up enough to soften to ideal...just speculation though.
The summer Dunlops did wear faster than the PSS, which likely wear faster than the winter Dunlops.
PSS ride a bit nicer with softer sidewalls; I have mine at 35 psi instead of stockers at 29 psi, to make up some stiffness and help steering input transient response, vs the very stiff sidewall stockers.
Rain/wet the PSS are better, more grippy thus more confidence inspiring than either of the stock Dunlops.
The PSS in 285-30-20 look smaller on the rear than stock, they have a slightly smaller tread width than the stockers. They kind of "trapezoid INWARD" from rim to tread, not BAD but not a good look either, needs bigger size in back to look best
It bothers me some, such that I will try going to a larger width including higher aspect ratio if I have to, to increase rear tire size, when these wear out.
I will try to keep using the PSS, as they are about $200 EACH less than the stock Dunlops...$800 a set, a not inconsiderable sum.
