1 - 20 of 48 Posts
Curious how everyone has gotten into the 10's in the 1/4 mile.
List mods, tire set up and lc
Thnaks
Founder/Admin
you mean to just run like a 10.9? thats pretty simple
09-10 on average can probably do it with just bolt ons and a Custom Tune mainly with midpipe stock LC2 VDC off OEM tires ( downpipes and intake are recommended but not 100% necessary)
2011 the same but might have a problem with VDC coming on with stock LC3 as it requires RRR
2012 can do it with just a midpipe or maybe even stock on 0 or negative DA night
13 should be able to stock or worst case just a midpipe like the 12
my 2009 ran in the 10's with just a tune...
Tune & MidPipe slam dunk! (No need for downpipes in my opinion)
Gojira driver
Is there a substantial difference between running a y-pipe and tune vs. downpipe +/- intake with y-pipe and tune? How much more gain can I expect?
The downpipe and intake are definitely good for some additional power. Depending on the tune and which intake/downpipes you get I would say they are good for about 25-30 additional HP.
As Ryan said you will see about 20-30whp peak, but you can count on about 60whp more at redline. Doing the downpipes really opens up the turbos to breath up top so you will see more gains the higher in the rev range you go.
~Cicio
Yes sir I agree...just a tune will do it, but y-pipe and tune will do it all the time every time, no matter what part of the country you are in.
Not where I am
physical elevation of 5,280 and DA's in the 7-10,000 range. You don't want to live in Denver if you want to run good 1/4 mile times. Always funny for us Denver guys to hear the rest of the country complain about lousy 200-1,000 DA's
Not where I am
I was waiting for you to chime in.
You are just bitter because the tracks in Florida are open year around and are downhill.
good info!!
amazing breaking into the 10's with a few bolt-ons and tune.... or some just tune beauty!!
Yesterday at the PBIR rental, I hit 10.79 twice. Best slip was [email protected] .
Hit 10.8's multiple times. Church also hit a bunch of 10.8's.
I'm on the stock Bridgestone Runflats, Jack tune, HKS resonated mid pipe.
DA in the 800-1200 range.
Discussion Starter · #18 ·
Very nice mph
What 60's were u getting? Launching at ? Tire pressure?
I saw the vid with all the high HP cars in the 1.7x range. The one white high 9 sec was pulling 1.5x
Here is the slip.
I am in the left lane, and another GTR (red) was in the right. I believe he had a tune and full cat less exhaust, other mods I am not sure of.
Discussion Starter · #20 ·
well first time to the track many low 11.x passes at 129mph but the best of the day with stock run flats was 11.0 @128.8mph 1.78 60' it was spinning tires all of second gear.
40 degrees and no heat in the track at all since it was a rental and only 5 cars were running.
tire pressure was set to 28 psi.
how low do you guys go on stock run flats to get 1.6 60'?
1 - 20 of 48 Posts
