I had issues with my previous Protune on a mustang dyno. After posting my datalogs many approached and gave me the same feedback about my fuel trims, a/f being way off. I recently had a re-tune done on a dynojet by Rob from Kaizen Tuning. He did an amazing job, the car feels smooth, and I feel more comfortable after reading my new datalogs (not an expert in reading logs). (Datalog not uploading for some reason)
its not much about safe as they are efficient, stock turbos can peak 21 and i would always keep around 18 at redline max, thats with upgraded actuators. this also depends on your heat exchanger and how well it cools your charged air
I managed to do a new datalog, i had the transmission on "R" mode because I wanted to hit 7K rpms. I was a little slow in shifting to 4th. Car went past 7k and shrugged a little, felt weird. I've been paranoid ever since I increased power and lost warranty. Is that normal, when going over 7k and slow shifting?
In R mode the car will let you hit the rev limiter. If you have not ever touched it before it can be alarming. It will make loud noises as well as bounce the RPM. In R mode throttle and ignition cut are set to the same RPM. In normal mode you will get fuel get about 100 RPM earlier. One is what I would call a soft limiter the other a hard limiter. It's hard limited in R mode so you don't have throttle closure.
Stop being paranoid and just enjoy the car my friend. You got nothing to worry about. Car looks to be running great!
Yeah I normally shift way before, i just wanted to hit 7k to get proper datalogs. But as soon as it hit 7K it just jumped redlined and kind of hit back duno how to explain (similar to a single clutch kickback). Shouldn't be a problem right?
Been reading a lot about ecu logs trying to learn and understand more so I could look at logs and understand what i'm seeing 100%. Cobb keeps updating they're AP software so number or degrees keeps changing making it confusing to keep up. I would like to know what are the safe parameters. For example I know that (A/F Corr%) should range from "97-99" with a 5% variance etc...
What about: -Dynamic Adv. (°): this should be 0 to 1 max correct?
-High Det. Flag (0/1) ?
-Ign Advance (°) ?
-Cam Adv B1 (°) ?
- Max Neg DA (°) ? : Mine is mostly 9° or 7
-Trans Req. Tq. 1 (raw) ? i don't know what this is, mine has always been in 4094.
I'd appreciate any help in explaining the above, and what are the safe parameters. Thanks !
This will always be zero or negative as I do not allow the ECU to add dynamic advance only subtract. Letting the ECU add timing just always end up bad eventually
High det flag will be 0 or 1. 0 meaning safe mode is off. if the car pulls 4 degrees of timing (a dynmaic advance of -4 or higher) it will trigger safe mode and high det will show 1
-Ign Advance (°) ?
Ignition advance is just how it sounds. Showing you the current ignition spark timing the car is running.
-Cam Adv B1 (°) ?
Cam advance is just how it sounds. It's showing you cam timing the car is running
Max DA is the max allowed timing the car can remove upon engine knock. Not really a useful parameter to watch as it's just showing you what the limit is set to.
TQ req is just a raw number the ECU looks at. It's 100% arbitrary and is not really a useful item to watch.
Related Threads
Nissan GT-R Forum
1.7M posts
66.9K members
Since 2004
A forum community dedicated to Nissan GT-R owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
