1 - 3 of 3 Posts
I just purchased a used Cobb AccessPORT-005 from another member. It arrived today and after opening the package I inspected the unit. I noticed that the port at the bottom of the AccessPORT itself only had 9 male (gold colored) port pins but appears as though there should be 10. I then read the "Getting Started" manual and see that it says to connect the OBD-II cable to the "10 pin port on the bottom of the AccessPORT"
I do not have my GT-R yet so I am unable to confirm if the unit will still work despite missing a port pin!
Anyone know?
Thanks in advance.
Anyone know?
Thanks in advance.
With the screen facing upwards, look in to the "10pin" connector, the bottom right pin should be missing as this is completely normal. Also make sure the remainder of the pins look Ok and are straight and equal in length.
What a relief! The seller was great to deal with so I never thought I was screwed over but it just made me nervous! Thanks for the help.
1 - 3 of 3 Posts
