1 - 3 of 3 Posts
Wow...so many variables and discussions on which Cobb OTS map to run, but I haven't found anything specific to my config.
Currently running a Cobb Catted MP, and have a 3" intake on the way, stock DP, stock Fuel Pumps, stock Catback.
I do not plan on doing any custom tuning until I go full FBO E85, so I am just looking for some advice...
93 Octane is readily available and I am at Sea Level, although temps are hitting 95 degrees right now here in Florida.
Stage 1 + Big SF map (93 or 91 octane)
or
Stage 2 + Big SF map (93 or 91 octane)
I am not looking for all out performance at this point, but obviously I do want some additional safe hp/tq without maxing out the injectors or creating knock.
Any thoughts on running one map over the other? Any advice is truly appreciated.
You need the Stage 1 + Big SF map (93 or 91 octane)
I believe the biggest difference between the STG1 & STG2 is the waste gate settings.
If you had a upgraded downpipe the car would make too much boost on STG1 map..
Good Luck
John
1 - 3 of 3 Posts
