1 - 20 of 32 Posts
The car been running fine for a year after mods until yesterday morning The service engine light came on with message "engine system malfunction blah blah blah"
AP reads the code is ECU P0300 Engine control unit DTC's.
I reset it and it was running fine all day yesterday until this morning......lights on and same code.
It feels like it will come back after the car been off for overnight and cold start in the morning.
Any idea what the problem is please?
Mods are....
AP tune
650cc injuectors
Large MAF intake
mid-pipe + exhaust
· Premium Member
I dont know the codes off the top of my head, but I had the same message appear on my car, and it was because I forgot to reset the oil interval. Its simple enough to check, just see if it claims you are due for an oil change, and if you have been ignoring it.
Jon
· JDM R35 Premium
fouling spark plug?
· LiMiTLeSs
I got the same code this morning on my way off to the dealership for the bellhousing rattle issue. I just reseted the ecu and also my car has been sitting for like 2 months since the last time I started it up and drove it around. Additionally, it has been very cold outside so I figured that may be playing a factor as well. The light didn't come on again though after I drove it around.
If its a leaky injector and I get the light more frequently I suppose its all good as I'll be swapping my injectors out to the new TSM pro series hopefully that will fix the problem if that's the case.
Same issue here. P0300. Anybody get this resolved?
I get the P0300 code on mine too from time to time. Now that I think about it, it typically pops up on a cold start but not always. The odd thing is the same code would pop up in similar situations when I had my TT350z. I just turn it off and go on my way. Might change out the spark plugs to see if that helps.
· JDM R35 Premium
3 things to replace
1. Spark plugs
2. Coil packs
3. Injectors (the worst case)
Bumping this back up but i just got mine this afternoon after work. Seems kinda odd since i've been driving it the past 3 days, it has been sitting since January though. Are there any aftermarket coil packs to look into? Also how often do you guys change out plugs? I know i changed my plugs every oil change on my old evo since they're so cheap to buy. Mods are a Switzer p700 w/downpipes.
· LiMiTLeSs
Which plugs do u have?
· JDM R35 Premium
Okadas here with stock plugs
Mine did the same thing I changed out injectors and a reflash problem solved the code would come on after start up sometimes because it would misfire and be rough to start once the injectors were changed out it would start up smooth like stock no more codes
Bumping this back up with a update. Seems I only get this code in the morning when it's 30-35f. Got it the last 2 mornings and cleared it with the Cobb. Going to replace the plugs maybe. Anybody know the part number, gap size, and if I should be looking at any aftermarket ones?
· LiMiTLeSs
If you keep getting this code then you may have something up. Its either plugs, injectors, or something else. HKS makes aftermarket plugs but you should get OEM and their pregapped.
P0300 is a random misfire, usually bad plugs will give you individual misfires. Random misfire while cold could be dirty mass air sensor or vacumm leak ie intake gasket etc. I would look at short/long term fuel trims while cold.
1 - 20 of 32 Posts
