Because at 67 psi of fuel pressure (17 psi boost) it can flow 250 lph or approx. 430 lb/min which is greater than the 6 stock injectors max flow rate. Based on the test, the stock fuel pumps can maintain the pressure at the fuel rail as designed and adding bigger pumps wouldn't help because the fpr will just bypass extra fuel to maintain the designed pressure. So both pumps will see same fuel pressure.
That been say, the only way to prove bigger pumps help is it maintain a higher fuel pressure than stock (Such as stock can't maintain design pressure).
