Need help with spacers.
391 Views 4 Replies 5 Participants Last post by  AutoXGTR
2
Hi guys I feel like I need to put a small spacer in the front to give it a little more flush look but not sure what size spacer
Wheel Tire Car Vehicle Automotive lighting
Wheel Tire Car Vehicle Sky
1 - 5 of 5 Posts
Judging from here… I’d say 10mm
Just remember that the farther out on the front, the more susceptible rocks are to the paint.
And of course check with your local authority for legality.
Wheel Tire Car Vehicle Motor vehicle
Nice wheels ...What brand?.....
on topic: No clue about spacers..good luck
I mean giving information about your wheel size and offset is a start if you want someone to even give you a suggestion. But your best bet is to just measure how much further out you want your wheel to be and then buy that spacer. The amount of camber you have on the car also play a role in how much spacer you can or need to get to your desired look.
  • Like
Reactions: 1
Yes, the wheel specs for front offset would give us a better idea of how it compares to OEM 20x9.5 et 45. Adding a front 15mm spacer to OEM wheels helps make it flush fit.
1 - 5 of 5 Posts
