Hello everyone,
Just received word from Albins about this interesting new gearbox, which is a COMPLETE replacement for the GR6 transmission.
Current pre-release pricing can be found here on our website for the transmission plus clutch options and additional control items.
http://www.speedfors...x35-p-4117.html
Albins AX35 Transaxle
A bolt in heavy duty transmission for use in Nissan R35 vehicles with extreme power levels.This unit has been designed as a direct replacement for the OEM transmission with internals designed to withstand the rigours endured in applications where the power levels are approaching 2000hp.The transmission features are:
Pre-Delivery enquiries are being taken at present. Delivery to market date is expected to be Late April 2016.
Photo below of standard R35 Gear versus AX35 gear demonstrates gear tooth width differences.
I will post more information when available. In the mean time, feel free to contact me directly with any questions.
- 6 Speed Sequential Operation
- Your choice of steering wheel mounted paddle shifters and automatic clutch operation (like OEM), manual sequential operation with a clutch pedal (not a gated shifter), or fully automatic computer controlled
- Active centre differential
- Oil Cooled active centre differential
- Various clutched input options
- Dry multi plate clutch with manual operation (requires a pedal and master cylinder to be fitted to the car)
- Dry multi plate clutch with paddle control
- Stand-alone operation eliminates factory TCM limitations. This requires a stand alone ECU such as the Motec M1
- Replaceable drop gears front and back facilitate easy final drive changes for 1/8[sup]th[/sup] mile, short track to standing mile or terminal speed runs.
- Multiple inspection ports for easy internal inspection and low maintenance
- Gear Profile Ground gears for strength and durability
- Isotropically finished gears for wear resistance and friction reduction
- Wheel and Pinion manufactured with Klingelnberg Palloid system
- LSD rear differential or spool option
- Internal oil pump and filter system
- Can be packaged as a 2WD or 4WD installation
