I have a new design of subwoofer enclosure which has nearly 30% more volume than my original design. One of the reasons why I wanted to do this was open up the market for a few more subwoofer options which weren't designed for a smaller box design. I'm always trying to improve and push boundaries with this kit and still have a self fit mantra for those who just want to fit it in their own time with the minimum of effort.
The main design change is the angled sides to the box which, whilst harder to create, add much more internal volume. The volume has increased from around 0.32cuft to 0.43cuft. Its slightly larger in height, utilizing all the space behind the OEM Bose cover. You will see from one of the images below that I have even created a slope at the top where the car's shape naturally starts to rise. This allows a nice tight fit against the back of the firewall for a perfect fit. It also includes a larger notch cut out of the bottom to accommodate a fixing bolt built into the car.
The system is still plug and play and I am now using Audison only connectors and power wires for my kits. They are top quality connections and fuse holders.
My current subwoofer of choice has moved from Sundown to Kicker. The Kicker L7 Solobaric 8" driver is an awesome accompaniment to the enclosure. It needs the extra enclosure volume I've created and with a power rating 50% more than the Sundown, it really does kick hard. There is nothing wrong with the Sundown SD-2 sub and indeed, I still have some in stock I can fit but they are very difficult to get hold of in the UK and their customer service is not what I expected. I wanted to try the Kicker with its 20% more cone area than a traditional 8" round subwoofer. It also comes in both Dual 2 ohm or Dual 4 Ohm coils so I can present either a 4 ohm or a 2 ohm load to an amp which gives more flexibility. I am extremely pleased with the results and have the kicker in my car now rather than the Sundown.
Another subwoofer this new design has allowed me to use is the Hertz ES200.5 8" driver. This sub is Hertz latest 8" subwoofer, coming out only a couple of months ago. Whist this subwoofer can't create the same SPL level of the Kicker or Sundown, it a much more musical sub. It gives clear, clean solid bass and is very good value for money.
The price of this new enclosure including a Hertz ES200.5 is £259. The kit with the Kicker L7 Solobaric sub is £324.00. These prices include the plug and play wiring kit attached (power wiring up to 300w).
I personally use Hertz amplifiers due to their high power to size ratio and extraordinary sound quality. They have a range of amps which use a chassis size that fits perfectly behind the carpet in the trunk for an invisible install. There is a picture below of my Hertz HCP1D sitting in the recess behind the carpet. This little amp is digital so doesn't run warm. With 700w RMS from this little beast, it devours all the subs I've thrown at it. Not cheap at £249 but you get what you pay for.
If anyone is interested, they can be bought from my website http://www.R35Audio.com where there's a currency converter if required and US shipping is just £39. You are welcome to join the discussion at http://www.gtrlife.c...t/#entry1341130 , reply to this thread or drop me a Message on here
Thanks, Andy
Thanks, Andy
