Nissan Motorsports International, Inc. (Minami Ohi, Shinagawa-ku, Tokyo: President Shoichi MIYATANI), afterwards referred to as "NISMO", announces the release of the NISSAN FAIRLADY Z NISMO RC* (export designation: NISSAN 370Z NISMO RC). This is a production race car built up from the NISSAN FAIRLADY Z (export designation: NISSAN 370Z). The car goes on sale and orders will be accepted from October 3, 2011 on.
* RC=Racing Competition
■NISSAN FAIRLADY Z NISMO RC
This car uses Nissan's pride, the world renowned, high selling NISSAN FAIRLADY Z as its base. It has been adjusted for slick tires, its overall weight lightened and safety equipment installed to make it a top performance race car. It ran in the 2010 Super Taikyu (Super Endurance) series where it showed its superior maneuverability and reliability.
Its VQ37VHR engine puts out over 261kw (355ps) of power with over 374N▪m(38.1kgm) of torque. The car comes equipped with adjustable suspension and race spec brakes to guarantee maximum equilibrium.
It is furnished with a weld-in roll cage, bucket seats, safety harness, fire extinguisher and a 95 liter safety fuel cell. The NISSAN FAIRLADY Z NISMO RC is a fully equipped, professional racing car on purchase.
For customers who are interested in doing their own custom work, NISMO offers a "PARTLESS CAR" frame which is delivered without suspension, brakes, rear wing, seats, steering wheel, fire extinguisher, tires and wheels.
The NISSAN FAIRLADY Z NISMO RC is "made to order" and must be purchased directly from NISMO. (see notes below)
DIMENSIONS
Engine model VQ37VHR DOHC V6
Cylinder Bore 95.5mm × Stroke 86.0mm
Displacement 3,696cc
Power Over 261 kw @ 7,400rpm (Over 355 ps @ 7,400rpm)
Torque Over 374 N・m @ 5,200rpm (Over 38.1kgm @ 5,200rpm)
Rev limit 7,500rpm
Length 4,450mm
Width 1,870mm
Height 1,315mm
Wheelbase 2,550mm
Front track 1,601mm
Rear track 1,626mm
Weight 1,320kg
Power - weight ratio 3.72
ECM Manufactured by NISMO for the NISMO RC
ENGINE
Engine ASSY Manufactured by NISMO for the NISMO RC
INTAKE SYSTEM Air cleaner ASSY NISSAN Genuine Part
Airflow meter NISSAN Genuine Part
Piping NISSAN Genuine Part
Throttle chamber NISSAN Genuine Part
EXHAUST SYSTEM Exhaust Manifold NISSAN Genuine Part
Catalyzer Manufactured by NISMO for the NISMO RC
Muffler Manufactured by NISMO for the NISMO RC
COOLING SYSTEM Radiator
Engine Oil Cooler Manufactured by NISMO for the NISMO RC
POWER TRAIN
Clutch disc NISMO COPPERMIX φ240
Clutch cover NISMO SUPER COPPERMIX HIGHPOWER SPEC
Flywheel Manufactured by NISMO for the NISMO RC
Transmission NISSAN genuine part (w/ synchronization control)
Rr Differential NISMO GT L.S.D. Pro Carbon(2WAY)
Final Gear NISSAN genuine part (3.692)
T/M oil cooler Manufactured by NISMO for the NISMO RC
Rr Differential Oil Cooler Manufactured by NISMO for the NISMO RC
BODY
Body shell NISSAN Genuine Part
Reinforcement NOT supplied
Air jack Ap x 3
Fuel tank ATL 95 liter
Undercoat NOT applied
SUSPENSION
Shock absorbers OHLINS- adjustable height DFV 1WAY NISMO RC
Fr Springs SWIFT, springs rate: 20.0kgf/mm
(18.0kgf/mm & 22.0kgf/mm spring rates available on demand)
Rr Springs Manufactured by NISMO for the NISMO RC, spring rate: 20.0 kgf/mm
Link & bushes NISSAN Genuine Part
Front ARB Manufactured by NISMO for the NISMO RC φ34.0
(φ28.0 and φ31.8 available on demand)
Rear ARB NISSAN Genuine Part
CHASSIS CONTROL VDC NOT equipped
TCS NOT equipped
EBD NOT equipped
BRAKE
Fr Brake pads ENDLESS
Fr Rotors Brembo 355mm - ventilated disc
Fr Calipers Brembo 4 pot
Rr Brake pads ENDLESS
Rr Rotors Brembo 345 mm - ventilated disc
Rr Calipers Brembo 4 pot
Air duct Front φ100(rear: none)
ABS BOSCH exclusive for racing
EXTERIOR Fr bumper Manufactured by NISMO for the NISMO RC [ brake duct included ]
Fr rip spoiler Manufactured by NISSAN to Nismo specifications
Side skirts Manufactured by NISSAN to Nismo specifications
Back door NISSAN Genuine Part
Rr bumper Manufactured by NISSAN to Nismo specifications
Rr wing Manufactured by NISSAN to Nismo specifications
Bonnet NISSAN Genuine Part
Fr fender NISSAN Genuine Part
Door NISSAN Genuine Part
Rr window Acrylic t = 5.0 mm
Door mirror NISSAN Genuine Part
Tow hook Manufactured by NISMO for the NISMO RC
INTERIOR
Seat RECARO SP-G HANS
Seat belt NISMO Racing Harness(WILLANS-6 point harness)
Speedometer & tachometer NISSAN Genuine Part
Data logger NOT equipped
Steering SPARCO φ330
Roll bar JAF approved
Fire extinguisher Manufactured by NISMO for the NISMO RC, Automatic type
LUBRICANTS
Engine COMPETITION OIL type 2108E(0W30)
Differential COMPETITION OIL type 2189E(75W140)
Brake MOTUL RBF600
T/M Oil MOTUL for the NISMO RC
TIRES
Front YOKOHAMA slick tire ADVAN 250/660R18
Rear YOKOHAMA slick tire ADVAN 250/660R18
WHEELS Front RAYS TE37 NISMO RC 18×9.5JJ +12mm
Rear RAYS TE37 NISMO RC 18×9.5JJ +0mm
DIMENSIONS
Rev limit 7,500rpm
Length 4,450mm
Width 1,870mm
Height 1,315mm
Wheelbase 2,550mm
Front track 1,601mm
Rear track 1,626mm
Weight 1,320kg
ENGINE
POWER TRAIN
BODY
Air jack Ap x 3
SUSPENSION
TCS NOT equipped
EBD NOT equipped
BRAKE
INTERIOR
LUBRICANTS
Brake MOTUL RBF600
TIRES
