1 - 6 of 6 Posts
More and more injector upgrades are being placed on the market to meet the fuel demands of the more powerful GT-Rs out there. There hasn't really been much publicized testing or even acknowledgment of the standard injector capabilities versus after market items though. Garage Saurus have made it pretty simple for us with a nice visual you can check out below.
In their testing, the standard GT-R injectors flowed equal to a 570cc injector. You can see below the comparison with SARD 650cc injectors which flowed around 660cc for this test and BOSCH 750cc injectors which actually seemed capable of flowing up to 820cc in testing.
As a side note, Garage Saurus liked the BOSCH injectors so much they will be using them in a big injector bolt-on upgrade for the GT-R which they'll sell you for 24,000 yen a piece, or 144,000 yen all up. Don't all rush out and by them though because the GT-R still needs something to control these big injectors. The standard ECU is out of it's depth with injectors of this size.
Link: Garage Saurus' R35 Tuning Website
View Entire Article: Nissan GT-R Injector Flow Test Comparison and Future Upgrades at GTRBlog.com
Originally appeared on and © GTRBlog.com. 2009. | Read comments.
www.goturnstop.com
spray pattern on the 750 looks better than the two jets on the 650 or the stockers.
Not really.
The spray pattern on the OEM is designed for a split port 2 valve design w/ a 15deg divergent pattern. The Bosch spray pattern is a simple cone. Which is more prone to wet the port webbing. Not saying that the Bosch won't perform better but there is a reason the other 2 injectors spray pattern have that shape.
Not really.
Well, that does make sense. But how will the two solid jets of the 650's mix- homogenize?
www.goturnstop.com
A picture doesn't tell the whole story.
So I'm wary to offer an opinion on the SARD injectors. I know alot of guys that use them in the Nissan world. My first hand experience is limited w/ them.
Bosch injectors are very good good in terms of build quality and flow rates. Use them in numerous projects.
1 - 6 of 6 Posts
