1 - 20 of 66 Posts
Founder/Admin
Here you will find the latest Technical Service Bulletin (TSB) and Recalls that Nissan has Issued for the GT-R
Check back for the latest additions
**We provide these for informational purposes to our members , please consult your dealership and certified technicain to perform the actual repairs
Founder/Admin
Discussion Starter · #2 ·
2009 - 2010 GT-R RATTLE FROM FLYWHEEL HOUSING
APPLIED VEHICLES: 2009 - 2010 GT-R (R35)
IF YOU CONFIRM
A rattle noise coming directly from the rear tail shaft area of the flywheel housing,
NOTE:
• The GT-R transmission has different operating characteristics than a typical passenger car. Because of this, various driveline rattle noises may be heard during some driving conditions. These normal characteristic noises do not indicate a malfunction. Refer to the Owner's Manual for addition information on transmission operating characteristics.
• When placed on a lift and listening from under the vehicle, the source of the typical GT-R driveline rattle noise is from the center of the main driveshaft or near the rear mounted transmission. A rattle noise caused by the flywheel housing will come directly from the rear tail shaft area of the flywheel housing.
• The rattle noise for this incident-if it should occur-can be duplicated by putting the transmission in Park or Neutral, then slightly accelerating and decelerating the engine.
ACTION
Replace the Flywheel housing with the new one listed in the Parts Information.
Founder/Admin
2009 - 2010 GT-R TRANSMISSION SIDE OIL SEAL LEAKING
IF YOU CONFIRM
A transmission side oil seal (axle seal)-left and/or right side-is leaking,
ACTION
Replace the oil seal and side flange.
• Do not replace the entire transmission when replacing an oil seal and side flange will repair the leak, if it should occur.
Founder/Admin
2009 GT-R; MIL ON WITH P0455 / P0456
**This bulletin has been amended. The DTC list has been revised. Please discard all previous copies of this bulletin**
APPLIED VEHICLE:2009 GT-R (R35) APPLIED VIN: Built before JN1AR5EF(*)AM 230219 APPLIED DATE: Built before December 24, 2008
IF YOU CONFIRM
The MIL is "ON" with DTC P0455 (EVAP Control System Gross Leak) and / or P0456 (EVAP Control System Very Small Leak) stored,
and
The fuel filler cap is installed correctly.
ACTION
1. Replace the EVAP Canister Vent Control Valve.
• Make sure to use the "new style" valve listed in the Parts Information.
Founder/Admin
2009 NISSAN GT-R; VOLUNTARY EMISSIONS RECALL CAMPAIGN ECM REPROGRAM
NTB08093
Nissan has determined that some 2009 model GT-R vehicles may be equipped with an improperly functioning on-board evaporative emissions diagnostic system. The evaporative emissions purge monitor ratio within the Engine Control Module (ECM) may be lower than the OBD-II regulation standard. To correct this condition, Nissan is conducting a Voluntary Emissions Recall Campaign to reprogram the ECM at no charge for parts or labor. See this bulletin for further detail.
Founder/Admin
2009 NISSAN GT-R VOLUNTARY SERVICE CAMPAIGN STEERING LOCK UNIT
NTB10-025 Recall
Nissan is conducting a Voluntary Service Campaign to replace the steering lock assembly on certain specific 2009 model year GT-R vehicles due to excessive oil within the assembly, which could cause the Body Control Module (BCM) to prevent the engine from starting when the ignition is cycled. This issue does not affect steering or engine operation when the vehicle is already running.
Founder/Admin
2009-2011 NISSAN GT-R MIL "ON" WITH DTC P0729/P2832 STORED
For 2009 - The MIL is on and DTC P0729 (6GR Incorrect Ratio) is stored
For 2010 - The MIL is on and DTC P0729 (Sleeve A1 Function) is stored
For 2011 - The MIL is on and DTC P2832 (Shift Fork A) is stored,
IF YOU CONFIRM For 2009 - The MIL is on and DTC P0729 (6GR Incorrect Ratio) is stored, For 2010 - The MIL is on and DTC P0729 (Sleeve A1 Function) is stored, For 2011 - The MIL is on and DTC P2832 (Shift Fork A) is stored, ACTION Install Metal Caps on 3 of the shift pistons in the transmission Actuator Control Module (ACM)
Since some of the above posts are old. Do any of the earlier posts affecting '09-'10 GTRs also affect the 2011's? (in other words have they been extended into the 2011 model years)?
JDM R35 Premium
IF YOU CONFIRM
ACTION
I got this and I got JDM in UK nobody is going to help I think.
dealer just called there is a recall on the 2012 something about the trim around the A pillar turning cloudy? Anybody hear about this? mine is not doing this by the way.
Founder/Admin
Discussion Starter · #11 ·
NTB11093
  • Certain 2012 GT-R vehicles, due to a manufacturing irregularity, may develop poor appearance on the front pillar finisher. To prevent this potential condition, Nissan is conducting this voluntary service campaign to inspect and if necessary replace the front pillar finisher at no charge for parts or labor. See this bulletin for further detail.
Hi, does anyone have this Service Bulletin Number as a .pdf?
Make : NISSAN Model : GT-R Year : 2009 Manufacturer : NISSAN NORTH AMERICA, INC. Service Bulletin Number : NTB-10-061 Date of Bulletin : APR 27, 2010 NHTSA Item Number : 10032992 Component : EXTERIOR LIGHTING:HEADLIGHTS Summary :
NISSAN: XENON HEAD LAMP SERVICE. A XENON HEADLAMP IS NOT FUNCTIONING BECAUSE OF AN ISSUE INSIDE THE HEADLAMP ASSEMBLY (AN INTERNAL ISSUE). IN MOST CASES, REPLACEMENT OF A BULB OR HID CONTROL UNIT WILL SOLVE THE INCIDENT. THIS INCLUDES ALL MODELS WITH XENON HEAD LAMPS. NO MODELS LISTED. *PE
Great thread
Just reading some of these TSB's and just wanted to point out one thing. When identifying a TSB: or asking about one make sure that you identify which country your inquiring about. Is it Canadian,USA,Japan, uk etc. TSB's aren't the same for all countries and they do not crossover! They may have similar ones but again a different #. It will save you alot of time.
My .02
T
Isn't there one for the dash light? Are they anymore?
My 2010 had illumination degradation of the gas gauge, it will spread evetually to other areas of the cluster. Warranty extended to 6 years as this is a common problem. Go to the dealer and they will match the milage on the newly installed cluster. MC thanks for this thread
Thank You.
Anyone know if there is a recall for the battery?
1 - 20 of 66 Posts
