1 - 10 of 10 Posts
Rattle is completely gone, no more annoying sound that sounds like your car is falling apart, is just smooth and it seems like less clunking too.
They told me they didn't drop the engine at all not sure how and there is like a long long list of parts that they replaced under warranty, i will post the detail later, seems like some turbo parts involved...weird.
Sorry, what is tsb?
· Super Moderator
Is there a number for this TSB, that you might print out?
Alexd
Jeremy, they didn't install the DP, they said will be too much work.....
Have 17k miles on it, no need to fight for it. I mentioned I would like to get that done and they told me they have to check it and make sure it needs it. Then they just called me and said "yeah you need it" .
I don't really think a dealer will try to not give you the job, the get paid from Nissan.
I don't have the # for that, I just asked for "bell housing TSB"
I will post the parts list was invloved.
Damn the OCR, all "O" should be a "0"
32040 -JFO2A <---may be this is the bulleting number
PARTS------QTY--- FP-NUMBER --------------- DESCRIPTION --------- LIST PRICE-UNIT PRICE-
1 32040-JF02A FLYWHEEL-HOUSIN WARRANTY
1 01558-00721 CLAMP-HOSE WARRANTY
3 01558-00721 CLAMP-HOSE WARRANTY
2 16439-7SO1B CLAMP WARRANTY
2 01558-00561 CLAMP WARRANTY
1 21481-18000 GASKET-COCK WARRANTY
2 20692-24U00 GASKET-EXHAUST WARRANTY
1 20692-JFOOA GASKET-EXHAUST WARRANTY
1 060241tUU NUT-FRONT EAIIAU WARRANTY
2 08918-3401A NUT-FLANGE WARRANTY
1 14445 -JFO1A TURBOCHARGER OU WARRANTY
1 14445-JFO1B TURBOCHARGER OU WARRANTY
7 14094 4P110 NUT WARRANTY
3 14094-4P110 NUT WARRANTY
2 21304-JFOOA RING-RUBBER WARRANTY
4 37120 CG1OA BOLT-FIX PROPEL WARRANTY
4 37120-JF01A BOLT-FIX PROPEL WARRANTY
4 37120 -JDOOB BOLT-FIX PROPEL WARRANTY
4 37171-7SOOA NUT-FIX PROPELL WARRANTY
6 37120-JFOOA BOLT-FIX PROPEL WARRANTY
5 11298-4M418 BOLT WARRANTY
2 54588-1BA2A NUT WARRANTY
2 08921-3252A PIN-COTTER WARRANTY
1 40260-EG010 NUT KNUCKLE SPI WARRANTY
2 40043-0L700 PIN COTTER WARRANTY
1 30417JIOOA COVER-RR PLATE WARRANTY
1 92474-N8210 0-RING - A/C WARRANTY
1 92472-N8210 0-RING - A/C WARRANTY
Also did oil change $160 and POS service.
Also fix the ticking noise by Lubricated front axles and hubs (temporary fix)
· Super Moderator
Thank you!
Alexd
1 - 10 of 10 Posts
