Alot of discussion about Nismo lately so thought i'd post up info on their turbo's
The Nismo turbos feature larger compressor and turbine wheels than standard GTR turbos.
A standard GTR compressor wheel measures 56.00/43.38mm whereas the Nismo item measures 60.00/46.45mm.
The individual compressor wheel pictures above aren't actually the Nismo wheel, theyre a near identical wheel of the same dimensions from the IHI catalogue (the only difference is the wheel has a curved leading edge to the compressor wheel whereas the Nismo (like the stock GTR) has a square edge). The Nismo wheel can be seen on the CHRA images.
The turbine wheel is where the biggest change happens; a wheel of a different design is used (again the individual wheel pictured isnt from the Nismo turbos but is an identical wheel from another application). The turbine wheel increases from 52/40mm to 53/48mm and the number of blades increases from 9 to 11.
Overall the Nismo turbos are a decent upgrade over stock GTR turbos. We do actually offer turbos with this Nismo sized turbine wheel already (and have done for a number of years) so we have a pretty good understanding of its flow capabilities in the R35 housing. The IHI based turbos available through Linney Tuning use larger parts than the Nismo.
Pics show comparisons between stock GTR, Nismo and Linney IHI spec wheels.
