1 - 8 of 8 Posts
Time will show whether these are nice.
405mm PFC front.
390mm Racing Brake rear.
Time to test the ability to control the GTR in motion at speed!
Stay tuned.
Member
405mm PFC front.
Stay tuned.
With OE calipers the maximum front rotor you can install is 395mm w/o modification, which gives you a minimum clearance of about 1.5 to 2mm top rotor edge to the caliper. Any size larger than 395mm you must enlarge the caliper curvature by grinding off the caliper as shown in hatch area to avoid interference.
The amount of removal depending on the rotor sizes, if you have say a 405mm rotor; (405-395)/2 - About 5mm is what needs to removed, you can use a feeler gage to check the clearance with rotor & caliper installed.
This advice is provided by us strictly for fitment aspect only (avoiding interference). It by no means imply such modification is not w/o affecting the integrity of the caliper strength especially if for track application.
I am at 20000 miles
1 - 8 of 8 Posts
