1 - 8 of 8 Posts
Temps are hovering around 0C here. GT-R apparently doesn't have a block heater.
Has anyone put one of those stick on oil pan heaters on their car?
Warex you are freaking awesome.
In theory, if we look back there, we should see a spot to plug the block heater cord into? I haven't seen any 120VAC cords laying around in the engine bay, and I'm assuming since it's a canuckistan car, that it should have the plug installed, just needs a cord.
Asking my first question again a little differently, with the oiling setup on the R35, Will putting a traditional stick on oil pan heater on the oil pan do anything? I looked at the ESM, and with the wet/dry sump setup I think the car has, I couldn't find any kind of oil reservoir documented anywhere, so I'm thinking a pan heater should work fine?
1 - 8 of 8 Posts
