It'll be soon a year ago that I bought a brand new GT-R35 Black Edition.
First list of mods:
HKS Superior Spec R CatBack
HKS Resonated Y-PIPE
COBB Down-Pipes
Upper IC pipes HKS SSQV-III
NISMO oil cap (+0.00001hp)
NISMO cadiator cap (+0.00001hp)
COBB custom tune
CARBONETIC SPEC-R pads
After about 6 months driving it like that (6000 track kilometers) it was time for more power with our proper specs:
HKS turbine kit with full ceramic coating:
HKS dampers:
Coated intake manifold:
Koyo water radiator:
HKS cams and springs:
Cosworth rods with our custom spec DLC COSWORTH F1 pistons :
A bit of gold reflector:
Added to this:
Alcon brake discs
ADV.1 wheels
ID 1000
HKS IC kit
HKS oil pan
HKS diff cooler
HKS gearbox cooler
HKS fuel pumps
T1R fuel rails
Carbon intake kit (formula one spec prepeg carbon)
Carbon ic piping kit (formula one spec prepeg carbon)
Every single Whiteline component available has been installed:
A little look of the DLC pistons in the block:
Some more gold reflectors:
Sneak pic of the diff cooler:
1st run is stock, 2nd is when we bring the car a few months ago (exhaust/intake/fuel pumps and rails but stock injectors/turbos/engine) with the injectors at their limits and 3rd is with the built engine and turbine kit (21psi).
All these are on pump gass (97).
This is the limit of the injectors (90% IDC) but we went to a little try.
For the fun we tried a bit more solenoid duty cycle resulting to 2 bar of boost ... and 1035hp at the hubs ... still on 97 pump gas but way out of fuel so that's the only run we did at that power (did a dozen of runs per boost until te 787hp at the hubs but didn't felt like doing more at higher boost once reached 90% IDC).
First list of mods:
COBB Down-Pipes
COBB custom tune
HKS dampers:
Added to this:
Alcon brake discs
ADV.1 wheels
ID 1000
HKS IC kit
HKS oil pan
HKS diff cooler
HKS gearbox cooler
HKS fuel pumps
T1R fuel rails
