1 - 9 of 9 Posts
I haven't been driving my GTR a whole lot lately, so it has been sitting a lot in my hot garage. This has happend to me twice now and I was wondering if this could be heatsoak or something else. I start it after it has been sitting for a long time and it sounds like it is misfiring, so I shut if off and pull the code and it pulls a P0301 code. I let it sit for a few minutes and start it back up and it runs fine. Then the rest of the day drivng it I have no issues at all. Just wondering if anybody else has seen this before. Usually in the summer I do drive it more, but working from home I haven't driven it has much. I replaced the plugs last year and the tune is ECUTEK currenltly running E85 just to provide some other details. Thanks!
Thanks! How would it leak into that cylinder? Wierd thing is it doesn't fix itself no matter how long I leave it running for. But if I turn it off for a couple minutes and start it up again its fine. I just started it up after it has sit for a few days and it is perfectly normal. Just seems wierd.
Headgasket - Valve guide seal. Could be a bad coil, electronics can seem to fix themselves when they get warmer and stuff expands. Move the coil to a different cylinder to eliminate that. I doubt it will keep misfiring after driving it for10 minutes (you said it goes away once you restart it).....try it to see if it goes away Just ideas...
I don't see and coolant in the oil. I will try to move the coilpack. Last time I did drive it around my neighborhood for about 10 minutes, but it didn't get any better till I shut it off for a few minutes. I have had misfiring issues with other cars, just never seen one like this. Thanks
Yeah the tune has been on there for probably 5-6 years now with no changes. I will go the coilpack route to see if anything changes. I have probably only put 1000 miles on it in the last year so it definitely doesn't get driven enough. Its been so hot here, so not as enjoyable. Thanks again
I just started and drove it today for the first time in a month or so. Ran great and no issues, but definitely cooler out now and my garage is heated so doesn't ever get above 70.
1 - 9 of 9 Posts
