G
Guest
·another check engine light, happens every sunday like clockwork! driviing a little over 50mph in 4th gear, almost no throttle input when BAM T/M malfunction, Engine malfunction, check engine light, flashing transmission light. no boost, only have gears 1,3,5,R. will not rev over 3000 rpms. Something about the car being in 4th gear in manual mode and light throttle being applied around 50mph.
*** One interesting thing is while cruising at a steady speed in 4th, the 4 will flash and the engine rpm's will drop to idle for two seconds and then it will go back to normal. has anyone else recognized this? try driving around several miles in 4th gear to see if your car has the issue. it did it 3 times tonight before finally putting me into limp mode. It's as if the gear selector sensor loses track of what gear it's in and flashes as it tries to find it. then gives up and goes into limp mode. maybe i need those rare little solenoid caps in the transmission? this car is driving me nuts! if you have any info on this or links to share please chime in!
