The problem started after I removed the cluster to repair the LCD panel.
After installing the cluster, the parking brake light does not turn on when the parking brake is lifted.
I have checked and ruled out the followings:
1. Dead parking brake indicator LED
2. Faulty parking brake sensor.
3. Broken wire from the sensor to cluster connector.
I am running out of ideas on what else to check. My suspicion is the problem is within the cluster circuit.
Is there any procedure I missed? Any advice is appreciated.
