Passenger window goes down when opening door
1697 Views 6 Replies 5 Participants Last post by  enshiu
has anyone encountered the passenger window goes all the way down when opening door then won't come up when closing with the window switch? Mine is doing it now. I did checked the fuse and the fuse is good. Any suggestions to fix these?
1 - 7 of 7 Posts
It happens quite a bit with the Infiniti G35 I forget how they fix it but it is a small problem. There is a sensor in the window that is used to stop it when it touches something.
As lilg210 mentioned that happened to me on a G37s when the battery got low. There was sequence of key presses to reprogram, I'm going to see if I made a note of it.
Try this:
http://www.nicoclub....d-moonroof.html
or
http://www.nicoclub.com/archives/power-window-reset-for-later-gens.html
Thanks bdl99. I already tried that steps from our service manual and no luck. when the window goes down I can't make it go up. The window can go up if I just tap the window switch slightly before hitting the automatic up switch when I pull it all the way to automatic it won't come up anymore but pushing it will let the windows go down..
Try this:
or
http://www.nicoclub....later-gens.html
I had the same problem and couple days later it went away.
How long did it take?
15 min to fix.
press the window all the way down
contact off
lock your car
wait 3 mins
unlock your car
contact on (foot off brake)
try to close your window.
1 - 7 of 7 Posts
