.:Seller Info:.
Seller: Joshua Michel
E-mail: [email protected]
1995 Toyota Supra TT 6-speed
34,106 original miles
VIN#: JT2JA82J9S0028915
Asking Price: $75,900 CDN
Clean Vehicle History
No Liens
**SERIOUS INQUIRIES ONLY**
For questions regarding the sale of this car, please send me a PM or e-mail to the address listed in my seller info.
It is an original USDM Twin Turbo 6-speed Supra. Black/Tan was the original exterior/interior color scheme, respectively.
I purchased this Supra in March of 2008 in San Antonio, Texas from SF member "Cursed" (Adam). It had ~32,500 original miles on it at that time. Current mileage is 34,106 miles
I've owned it for 3 ½ years now and it has been a flawless car whether driving it in stock form or the modified state as it sits now.
In April of 2010, the car was transported down to Austin, Texas where Chris Johnson of Performance Motorsports transformed the stock Supra into the highly modified street Supra you see today. In September of 2010, the Supra was picked up from Austin, TX. Completely tuned, mechanically sound, aesthetically stunning.
I am very picky when it comes to the modifications and maintenance of my Supra. Aside from Chris Johnson and the select few who worked with him on the build, I am the only other person to have worked on this car.
The car is tuned for 91 octane pump gas and VP C16 race fuel, making 575 RWHP and 858 RWHP respectively for each fuel.
The car has all of the original panels and all of the original paint - all of which were professionally wetsanded and buffed when it was in Austin, Texas. The front bumper is a new 1995-style bumper which was painted OEM black to match the rest of the car. I have the original bumper which will be included with the sale. I swapped bumpers because the original had a licence plate holder. The new one does not.
The interior was changed to black (carpet only). The rear seat is still the original tan. My plan was to have it reupholstered in black alcantara to match the Bride seats, but I was unable to finding the right shop that was up to completing the task, so it remained as is.
The only mechanical note is that the A/C was not recharged after the build in at Performance Motorsports. It is fully functional, just not charged.
I have documented history of the maintenance of the car, as well as every receipt for the parts, modifications and labour since I've owned the car.
There are about 350 miles on the motor. It was broke-in on the dyno and I've done 2 oil changes since then (about every 175 miles). It is ready to change over to full synthetic. Cold starts are perfect and the idle settles at around 1200 RPM after the engine is warmed up.
As a side note, there are about 350 miles on all of the parts installed on the car. Every part was installed at the same time, so they all have the same amount of miles on them as the motor.
I have only used C16 since I brought the car back from Texas, varying between my two preset boost settings of 17 and 31 PSI.
The car has never been tracked. There is not, nor has never been, a cage installed.
When the car is not in use, it resides in thermostatically controlled garage. During the winter months, it is placed on jack stands, under a satin car cover and a battery tender on float mode in the same heated garage, out of the elements.
That sums up the general details. For a more in depth look at the car (pictures, videos, specs) , please go to my "Member's Rides" page at the following link:
http://www.supraforums.com/forum/showthread.php?608306-1995-Toyota-Supra-6-speed-lt-Built-by-Performance-Motorsports-gt&daysprune=45
There are a plethora of build-progress pictures that were taken by Chris Johnson during the build in the above link, so be sure to check it out.
***Additional items being included with the sale of the car:
- Misc. tools (spanner wrench, lug nut socket, allen wrench)
- OEM Spare Tire and Tools
- All Manuals for aftermarket parts.
- Toyota Supra Owners Manual
Vid of 837 RWHP dyno run:
Vid of 858 RWHP dyno run: [media]http://www.youtube.com/watch?v=2ycW1DykcG8
BUILD LIST
Wheels/Tires/Suspension/Brakes
HRE 893R with brushed centers, polished lips
19x11 (Rear)
19x9.5 (Front)
Toyo R888 305/30R19 (Rear)
Nitto INVO 265/30R19 (Front)
KW Variant 3 Coilovers
Titan Front and Rear Sway Bars
Front: StopTech 13.1" BBK with silver calipers, slotted rotors, StopTech pads and SS lines
Rear: StopTech OE replacement slotted rotors, Hawk HPS pads, Goodridge SS lines, silver painted OEM calipers
Tilton TSR-1 Brake Fluid
Drivetrain
TRD 6-speed LSD
Performance Motorsports custom driveshaft
RPS Triple Disc Carbon Clutch
OEM Getrag V160 Transmission
Titan Motorsports Differential Ear Mounts
Turbocharger/Exhaust Components
Full Race T4 Twin Scroll Dual Wastegate manifold with black jet hot coating
Garrett GTX4294R with polished compressor housing
Garrett 1.28 A/R exhaust housing with black jet hot coating
Twin Tial 44mm MV-R Wastegates with 0.9 BAR Springs
Black jet hot coated wastegate dumptubes
Performance Motorsports 4" downpipe with black jet hot coating
Performance Motorsports 4" midpipe with black jet hot coating
HKS Carbon Ti Exhaust
Graduated 4" coupler to connect mid pipe to HKS Exhaust via v-band
Intake/Cooling
OEM Intake Manifold
OEM Throttle body
Greddy 4-row Intercooler
Tial Q BOV
Koyo Radiator
TRD 160 degree Thermostat
New OEM Fan Shroud
Polished Upper Radiator pipe
Engine
CP Pistons 0.020" 8.5:1 CR
Carrillo H-Beam Connecting Rods
Clevite H bearings
ARP Main Studs
Performance Motorsports modified oil pump
ATI Crank Damper
Unorthodox Racing pulleys for power steering, alternator and water pump
Boost Logic Timing Belt Tensioner
MVP Motorsports Upper shock arm
HKS Timing Belt
New OEM Power Steering Pump
New OEM Water Pump
New OEM Oil Pump
TRD Engine Mounts
NGK 4644 Spark Plugs
Headgames fully built head:
HKS 272 Intake and Exhaust Cams
Port/polish
Ferrea dual valve springs
Ferrea stock size valves
Ferrea Titanium Retainers
Ferrea Lockers
Ferrea Keepers
Shimless buckets
ARP 7/16" L19 head studs
OEM Cam Gears
Fuel System
Titan Fuel Rail
ID 1000 Injectors
Aeromotive Fuel Pressure Regulator
Dual Walbro Fuel Pumps
New OEM Toyota Fuel Filter
Interior
Bride Stradia Japan seats
Bride Type RO Seat Rails
New OEM black carpet
Alpine 9886 Head Unit
Rockford Fosgate 10" Stage 1 Power series subwoofer
Rockford Fosgate P-500 Amplifier
Kenwood front and rear speakers
Engine Management/Electronics
Haltech Platinum Sport 2000 EMS w/ PnP harness
AEM 3.5 BAR MAP Sensor
AEM AIT Sesnor
Defi Advance CR Control Unit with Oil, Fuel and Boost Pressure Gauges
Blitz SBC-i Color Boost Controller
FJO Wideband with 52mm gauge
TRD 10,000 RPM Tachometer
Exterior
1998 Style Headlights
1998 Style turn signals
New OEM 1995 front bumper without licence plate holder with single stage OEM paint
Complete wetsand and buffing of original OEM paint on all other panels of the car
MVP Motorsports Front Lip (Painted factory black)
Misc
TRD Oil Cap
Titek Carbon Fiber Spark Plug Cover
Titek Carbon Fiber Radiator Cooling Plate
Polished Intake Manifold
Polished Throttle Body
Polished Compressor Housing
Polsihed Valve Covers
Polished Power Steering Reservoir
Greddy Radiator Cap
No Liens
BUILD LIST
19x11 (Rear)
19x9.5 (Front)
Drivetrain
TRD 6-speed LSD
Intake/Cooling
OEM Intake Manifold
OEM Throttle body
Tial Q BOV
Koyo Radiator
New OEM Fan Shroud
Engine
Clevite H bearings
ARP Main Studs
ATI Crank Damper
HKS Timing Belt
New OEM Water Pump
New OEM Oil Pump
TRD Engine Mounts
Port/polish
Ferrea Lockers
Ferrea Keepers
Shimless buckets
OEM Cam Gears
Fuel System
Titan Fuel Rail
ID 1000 Injectors
Interior
AEM AIT Sesnor
Exterior
Misc
TRD Oil Cap
Greddy Radiator Cap
