1 - 20 of 25 Posts
Ordered quadzilla midpipe during Black Friday sale. About to install but found some issues passenger side is shorter and a little off angle. Emailed boostlogic waiting for response.
I compared it to stock and aftermarket midpipe
Bicycle part Wind instrument Gas Musical instrument Bicycle fork
I can move it up and try to compensate but one set of pipe is now longer
Cylinder Bicycle part Nickel Auto part Metal
Side by side passenger side is shorter
Leg Drinkware Gas Tool Thigh
Don't want to sound picky but would like it to be even.
If any one of you have one and not installed yet can you check. Or you have a good pic of it under car, are all pipes equal length
R35 member
If Im not mistaken, one side is always shorter. Its like that from the factory unless you maybe have aftermarket turbos.
Mine was same way. Bolts to stock turbos fine. The flex portion of the old midpipe can compress / stretch to account for the difference.... Similarly the quadZilla can compress / stretch (hence the side springs).
love mine.
What are your other mods?
Very nice setup... You're going to need injectors to get the most out of your tune. Bet your near 100% IDC
ID1000 here and ran the Cobb OTS stage 3. Crazy fast. Then Tim Bailey did e-tune and made it even smoother.
Just a FYI the quadzilla mid will pull the Akra rear section in more leaving the tips more inside the bumper cutout if you don't release the springs during the install.
Those look really sunk in, can try to loosen tips and extend it further out.
Here's mine, akra not installed I have different midpipe on
This weekend I will be placing my stock cats back on and compare them, my smog is due next month anyway
About the ID1000 with Cobb stage 3 how safe is that without fine tunning, any downsides. Also have down pipes sitting here. Will any Bosch ev14 made for gtr work or only id1000 and Cobb injectors. Might give it a try after I smog
I'm thinking of going with the GTC Titan 102 in a few months.
It does sound good though
You def need the tune for the Injectors but the OTS Tune was awesome ... I had an e-tune which I think made the car smoother, better idle, builds boost earlier ... But the OTS was a great map.
didn't do downpipes purely for sound (daily drive it a bit) but that left some easy horsepower on the table...
Like l said l have zero issue with my Cobb ots stage 3
Discussion Starter · #19 ·
Removed midpipe to test fit, ziptied in place, can adjust by twisting but can't makeup that 3/8" length
Check mating surface is pretty flat
Wheel Automotive tire Automotive lighting Tire Motor vehicle
Comparing midpipe can clearly see which one is off and Akra is 1/2" or so shorter in length because I had to pull the exhaust forward when I placed the akra in
Cylinder Metal Nickel Auto part Titanium
1 - 20 of 25 Posts
