1 - 20 of 45 Posts
Hey guys, in the near future I am doing engine build and upgrade turbo. Most likely, I have chosen who to go with. But I just want to make sure that I made the right decision.
For the engine internals, which would be better if price is not a factor and only quality and performance is prioritized.
JE Pistons and Manley Rods
OR
CP Pistons and Carrillo Rods
After doing some research, I am thinking of doing the turbo upgrade first since my engine is only around 16000kms. But I will definitely do the engine swap later after I put some miles on my current engine. I just thought it would be a waste if I swap the engine now and put my current engine sitting in the garage as I am using new core with my built engine. So I would appreciate it if you could give me some suggestion and advice on which one to choose. Thank you.
-Alpha 9 (My first choice)
-HKS GT800
-OEM IHI modified turbos
I have no experience in this, but Mahle Pistons with Cosworth Rods seems like a nice combo I would consider as well. However, the choices of internal components you have to choose from really depend on your target HP. Some pistons are stronger than others but will be heavier, so are the rods. The lighter the components the more responsive and the higher rpm you can go (assuming you have upgraded valve train and springs)
I'm selling my set of cp pistons Carrillo Rods with upgraded pins and bolts
You have a lot of good options. For pistions and rods I like Manley rods and JE Pistions. I have used JE's for years and they are great. Just make sure your piston and rod combo fits together, because some rods don't fit into some pistons.
As for the turbos you can't go wrong with any of the above, Alpha 9's have been proven, and work great. HKS 800 is also a very nice kit. And I also like my turbos
All of them have pluses and minuses.
anyone have feedback with brian crower rods and je piston combo? just ordered them for my car
Enthusiast
BC rods tend to have a lesser reputation than carillo, manley etc cause they are cheaper, but never seen one of their I beam (gtr rods) fail over internet boards. Plus they are a little lighter than manley (but heavier than carillo h-beam).
Would like to know if someone has any experience with the carrillo super a beam for gtr which should wistand 800-1000hp without problems for around 1100$.
GTC longer rods with custom short pin piston should be good for high pressure combo like gtx cartridge which like high pressure (less stress on the bores, longer rod/stoke ratio).
Sorry to thread jack.. Im wondering how you buy a set of matched piston and a set of matched rod combo without the need to rebalance the entire bottom end like the HKS piston and rod set. How does HKS do it?
Don't worry with HKS. I read that too. But I spoke at length with Shimada at Kansai Service which does alot of HKS builds and he said they rebalance regardless of Step 1 and Step 2
1 - 20 of 45 Posts
