Question for people running Armytrix exhaust
4.9K views 8 replies 6 participants last post by  vividracing
We are Armytrix North America. I'm happy to assist you with an Armytrix purchase. You will receive GTRlife member discounted pricing as well.
Regarding issues, they are quite rare. We sell many, many of these systems, and I believe we've only had two or three with very minor issues that were addressed by the warranty. Having us as your contact makes it issue to get tech support and assistance.
Regarding sound, it varies from system to system and based on whether or not you do a full system. The 90mm titanium system is the loudest and the 90mm stainless system is the least aggressive. The stainless system comes with a resonated midpipe. For those that want more sound, we have swapped those out for non-resonated midpipes from other brands to bring the volume up.
Feel free to shoot me a PM if you'd like to discuss the various options and pricing available to you.
-James
Can someone explain how it is supposed to work? Between vacuum and OBD2 data it seems like it should be pretty simple.
What fuses are blowing?
Why does one need the phone? Is that only for a custom "map"? Do they not load custom maps to the controller? Seems silly to depend on being connected to the phone when the map should be simple enough to store inside the controller; transfer from phone to controller via BT...
Trying to understand what and why the system fails for some people given it seems to be the best active valve choice (or is there something better?).
Thx,
Pete
The OBDII dongle includes two remotes. The phone app is optional. The advantage to it is you can see all sorts of readings via the OBDII.
Typically, dongle issues are encountered due to incorrect wiring and/or running OBDII splitters to allow other things to connect to the OBDII like Cobb. On the occasions that the dongle does fail, it's typically replaced free of charge, but this doesn't happen often.
Sounds Awesome!! Wouldn't go with anything else. I've had this for just about a year. No problems. I am running AAM mid pipe which I had before I got the exhaust. I would suggest getting the mid pipe too. Y pipe even better.
One complaint!!! I didn't get any stickers. You hear that Armytrix? If your reading this, hows about some free stickers.
Shoot me an email with your shipping info. I'll send you some stickers.
-James
