Stage 1
The Boost Logic Stage 1 package is a great way to get started modifying your GTR. Includes the free flowing Boost Logic 3.5in Y Pipe and proven Cobb Accessport. This combination has been proven to make up to 100hp and 100ft/lbs on an otherwise stock GTR. These parts are the same as included with the GTR640 and GTR725 kits, meaning they have the capacity to support higher power down the line.
Installed at our Austin, Texas facility for $1,899.00
For more information on this package, or any of our other packages feel free to contact us.
Boost Logic GTR640 kit
Boost Logic's newest release for the R35 GTR, Making an incredible 640hp crank HP on 93 octane pump gas and 690hp on VP MS109/ Pump 93 50/50 Mix with no other modifications.
The BLGTR 640 kit includes:
-Dual 3" to Single 3.5" Stainless Steel Midpipe
-Dual 3" Stainless Steel Downpipes
-Polished Aluminum Intercooler Pipe Kit with Blue or Black Silicone (option)
-EVC 6 Boost Controller
-SSQ Blow Of Valves Recirculated to Intake
-Iridium Spark Plugs
-Upgraded Turbo Actuators
-Cobb Accessport Tuning Utility
-Pre-Programmed Tunes for 91 or 93 Octane Gas
-Installation at Boost Logic Facility
-Before and After Dynocharts
Optional Parts:
-Carbon Fiber Cloth Boost Controller Mount Plate
All installed, tuned, and out the door of our Austin, Texas facility for $8,999.00
Boost Logic GTR750 kit
The BLGTR 750 Package includes:
-Upgraded Turbochargers
-Upgraded Fuel System
-Race Intercooler
-Cold Air Intakes
-Pre-Programmed Tunes for 93 Octane Gas
OPTIONAL
Installed and tunned at our Austin, Texas facility for $18,995.00
Boost Logic GTR850 kit
The Boost Logic 850 Package is perfect for the enthusasist that wants the most possible out of their GTR with out having to dive into the stock motor and transmission. The BLGTR850 Package incorporates the BLGTR Godzilla turbo kit, FMIC kit, Exhaust kit, and Electronics kit to make 850bhp while retaining near stock drivability.
The BLGTR850 Package includes:
BLGTR Godzilla Turbo Kit
- Custom Dual Ball Bearing Turbochargers
- Boost Logic Heat Shielded Water Line Kit
- Precision 46mm Wastegates
- Handmade Boost Logic 1 1/4 Tubular Headers
- Boost Logic Downpipes with Wastegate Recirculation
- Standard High Temp Coating on Headers/Turbine Housings/Downpipes
- Boost Logic Intercooler Piping
- Boost Logic 3in Intake Tubing (Available without MAFs)
- Custom Oil Feed and Return Lines
- Black Silicone Couplers and Clamps
BLGTR Custom FMIC kit
- Handmade race intercooler
- Polished FMIC piping kit
- custom mounted HKS SSQ BOVs recirculated into intake
BLGTR F16 Exhaust Kit
- Dual 3" to Single 3.5" Stainless Steel Midpipe
- Dual 3" Stainless Steel Downpipes
- Hand built 4" race exhaust system
- Hand built F16 style exhaust tips
BLGTR Fuel Upgrades
- Boost Logic dual fuel pump upgrade
- 1000cc Injectors
BLGTR Electronics/Dyno Kit
- HKS EVC 6
- Tuning Concepts dyno tune
- Iridium Spark Plugs
- Cobb Tuning Utility loaded with your personal tunes.
Installed and tuned at our Austin, Texas facility for $25,999.00
Boost Logic GTR1000 kit
For the BLGTR 1000 package, we took the BLGTR 850 kit and added our complete transmission package(which is a must for the GR6 to withstand 1000+ power levels) along with upgraded fuel lines and an HKS knock amp to ready the GTR for power levels about 1000bhp. The BLGTR 1000 package is perfect for the enthusiast wanting large amounts of power with out having to worry about the stock transmission hindering their goals.
The BLGTR 1000 Package includes:
BLGTR Transmission Upgrade Kit
- Custom internal transmission modifications
BLGTR Fuel Upgrades
- Upgraded custom fuel lines and fittings
- 1000cc Injectors
- HKS AFK Knock Amp
- HKS EVC 6 Boost Controller
Installed, tuned, and out the door of our Austin, Texas facility for $44,999.00
Boost Logic GTR1100 kit
The BL1100 Package is the beginning of our Built Engine and Built Transmission Packages. This setup will completely transform your car to horsepower levels beyond reach of any production vehicle. This package can be upgraded with options from our 1200 and 1300 packages allowing for even higher horsepower. Please inquire for more details.
The BLGTR 1100 Package includes:
Boost Logic GTR Rod and Piston Package for Stock Bore Motor
Custom Coated Pistons
Boost Logic Crank Pulley
Boost Logic L19 Headstuds
Boost Logic Main Studs
Boost Logic Race Bearings
Boost Logic Race Camshafts 264 Duration
Boost Logic Godzilla Turbo Kit with GT35
Boost Logic F16 Exhaust System
- Hand built 4? race exhaust system
- Hand built F16 style exhaust tips (or optional 5" Race Tube Tips)
Resonated Midpipe
Boost Logic Race Intercooler
Boost Logic Race Intercooler Piping with Tial BOVs
Boost Logic Fuel System
HKS Heat Range 9 Plugs
Cobb AP with Transmission Control
Boost Logic Trans Stage 3 Build
Stage3 800 ft lbs
PPg 1st gear set
Dodson Sportsman clutch
Dodson FWD retainer
Dodson Mechanical lock #1
Dodson Mechanical lock #2
O-ring and seal upgrade kit
Oil pump shaft upgrade with blueprint
6 neodymium magnets
High temp rear differential oil seal
Stainless re-usable internal filter
HKS Transmission Cooler
Tuning Concepts Engine Break In on Dyno
Tuning Concepts Dyno Tune Cobb AP
Boost Logic GTR1300 kit
BLGTR 1300 Package
$72,999.00
The BL1300 Package is for the ultimate speed enthusiast. Installed Vehicle Packages starting at $72,999, let us spec your vehicle to be the ultimate street machine. Please email [email protected] or call 512-371-9960 for more details.
