Jeremy above seems to be the exception with respect to the OEM rotors. Many have had their fronts start cracking after a handful of track days. I didn't wait for mine to crack, so early on I switched to AP Racing J hook rotors. I also started out with Carbotech XP10's, but currently am using Carbone Lorraine RC6E pads on the front and RC6's on the rear. Both make a lot of low speed squeal during daily driving, but it doesn't bother me much. I switched to the Carbone Lorraine because they last longer than the Carbotechs. I went through a front pair of XP10's in one three-day track weekend. I never used the XP12's as others with more experience had told me that the XP12's are too much pad for the OEM tires. If you're going to be using R comps on the track, then XP12's might be right for you, or the Carbone Lorraine RC8's.
I also replaced the OEM lines with Stillen stainless lines. Regarding fluid, I previously used Motul RBF600, which is fine, and never got mushy on the track. However, at the advice of a friend, I switched over to Castrol SRF, which has higher dry and wet boiling points than the Motul.
With my setup, I've never experienced any fade and for what it is worth, I do run in the advanced group.
