Very affordable plug and play solutions for all you MY2009 and MY2010 owners out there and don't think the cheaper price is because of the quality. This is a high quality solution with high quality components, just take a look at the reviews if you want a second opinion.
The Backup Camera Kit $450
Remote Bypass Kit $225
All the Bypasses you desire with a neat four button remote:
Also because any of these buttons can be paired with the home link buttons on the rear view mirror, you could for example:
AV Cable $50
The 3 RCA connectors (Yellow,Red,White) to allow connection of iPod and any other composite based video source.
Front Camera$160 $140 Introductory offer
Of course it goes without saying the front camera is the correct view and not reversed like the rear cameras
Highlights:
- Full step by step instructions with lots of pictures
- No soldering
- No cutting of any wires (when comparing with other kits ask if they require wires to be cut!)
- No drilling
- High Quality Kenwood Camera
- High Quality Composite to RGB Converter
- An input for the backup camera (kit comes with Kenwood CMOS-210), which activates when engaging reverse
- Two other inputs for front camera etc
- The additional inputs can be switched by a neat push to toggle switch that can be mounted without drilling any holes. There is also a remote supplied for switching if required.
- Button 1 activate parking brake bypass which can be configured to be permanently bypassed if desired
- Button 2 bypass of the speed sensor to allow navigation input while the car is moving
- Button 3 activate reversing cameras without needing to engage reverse
- Button 4 toggle the additional video sources, front camera in Karl's case (this does the same as the remote that comes with the backup camera kit but means you only need one remote)
- Press the first button to see the front camera
- Press the second button to see the rear camera
- Press the third button to bypass the speed sensor.
AV Cable $50
Front Camera
