1 - 9 of 9 Posts
· Hey girl, you got a soccer ball? Thought maybe we
I took my car for the first time after my build to the track and my back end was getting away from me way too much due to the added power. Any suggestions on how to keep it planted more aside from letting off the pedal lol? I have stock aero and running around 800 whp.
Sent from my SM-G920V using GT-R Life mobile app
using r888s?
· e85 member
Yeah, what wheel and tire setup are you currently running? Congrats on getting your car back!
Throttle- smoother input (roll onto the pedal) will help keep torque reduced to allow tires not to loose grip as easily (something RWD power car drivers must do)
More rear tire- use the widest wheel and widest tire with the softest rubber you can fit. Try slightly higher rear tire pressure and/or slightly lower front tire pressure
Use aftermarket adjustable coilovers- Stiffen front spring rate, soften rear spring rate, stiffen front shocks, soften rear shocks
Swaybars- if adjustable try stiffen front bar and/or soften rear bar settings
Aero- increase rear wing downforce
Oversteer info-
http://www.caranddriver.com/features/the-physics-of-oversteer-feature
http://www.drivingfast.net/car-control/oversteer.htm
1 - 9 of 9 Posts
