I have had a grinding noise from the rear end which I was pretty sure was coming from the diff, as it sounds like grinding metal pieces off throttle at low rpm and then goes away completely at higher speed...dealership and some people here have said it was normal.
Today I noticed that whenever I get it, even the slightest braking makes it go away completely. Has anyone had anything similar related to brakes? I'm going to try to see if there is something caught or warped leading to this sound but wanted to see if this was a known problem.
