I tested out some new pads that didn't work out so well because they couldn't handle the heat. The rotors ended up getting quite a bit of pad deposit on them causing a lot of vibration and judder. I need to remove the deposits. The rotor and pad manufacturers suggested heating up the rotors with torch and sscrubbing with coarse steel wool and then cleaning. Other sites have suggested temporarily using pad that is very abrasive when cold to remove them, but obviously I would have to buy them.
Any thoughts on the best method? I am actually getting DTC-70s to put on after I fix this. I don't relly want to use them to remove the material but I suspect doing the first method listed should work out and then the DTC-70s may fully complete the process when bedding in...
Thoughts?
Thoughts?
