Replace batteries on GTR Key
28450 Views 52 Replies 26 Participants Last post by  alexdavis
Hi all,
How do you replace the batteries on the GTR Key? What kind of batteries? Help is appreciated. Thanks
1 - 20 of 53 Posts
Buy the batteries on eBay if possible, much cheaper than stores.
i just got batteries from normal store .. removed key part from remote and split open ..
Hi all,
I'm going to ask the obvious just to make sure. Have you tried charging the FOB in the car?
Pretty sure the fob doesn't charge in the car slot. Besides, replaceable batteries do not recharge.
It's pretty easy.
Take the manual key out, then split the fob open from top. You can use your nails or a small knife.
Replacement battery is a CR2032
The batteries are a couple of bucks....how much can you possibly save on ebay....
If you have a good relationship with your dealership, they will replace them for free.
I was bored, here you go.
Don't mind the radio...
A couple of bucks.
Oh wow...learned something new. A bit disappointing though. It seems like most cars that have that, it charges the FOB.
Me 2. Split the FOB using a box cutter.
BigLots have this battry for $2 and a set of four.
this was helpful... took a bit of fiddling to open, but between fingernails, a butterknife, and a box cutter, the box cutter worked out best. There are some instructions on the interweb that tell you do put a screwdriver in the manual key slot... don't do that, definitely not how these guys are supposed to open.
If I remember right, the manual states that in the case where the key fob battery is discharge..insert key fob in slot to allow the car to be started...then replace battery. They are not rechargeable.
Pikes Peak R35
Agree, following the manual will result in damage to your key.
Go to your local Nissan (GTR) Dealer, pay $8 for them to replace it (like I just did). Are you seriously trying to save less than $8 on a key for a $100k car?
But its like replacing batteries on a tv remote.
Pikes Peak R35
autozone sale Replacement battery is a CR2032
1 - 20 of 53 Posts
