a solid custom tune will help. Large decatted downpipes will help the most.
currently am using the harmon motive intake..honestly, i'm not looking for bigger power,having enough than i can use..but just felt a need for faster low rpm rev or should i say response...With the turbos from the spec V, I can hit 600 ft lb @ 3000rpm. Talk about response. I dialed it back to about 525ft lb to conserve the rods.
high flow throttle bodies won't make a tremendous difference. What intake do you have? I free flowing intake like the Gotboost intake or HKS will do well to help you response also. You'll also make some more powe
yes!! thanks..I think the OP is referring to how fast revs build up, he wants it to rev more freely like an NA motor with lightweight flywheel. Not sure?
