Hello, 10 months ago i had a gearbox rebuild by a gtr workshop from czech after 1-r shift fork failure on a 2009 cba model. They replaced clutches with 7 plate packs, a and b clutch baskets with billett ones and a billett 1-r shift fork along with allwd rebuild, syncros change and circlip upgrade. Since rebuild i did aprox. 2kkm. The car behaved strangly after rebuild, it was like sttutering when take off on incline. Same thing happend on lc4 or lc5. The builder said i should rid the cobb and use ecuTek software?? A month ago or before 200km the car started to almost stall if the odd gear correction wasnt on -3 or -4. It did the gear relearn no problem every time. Yesterday the car threw the p284b code when i started the engine on driveway. I drained the oil today, it was clean, intake filter also but dodson main filter was coated with black debris. Also 1-r sift fork was aproxx 2mm out of position. I positioned the fork and cleaned the filters. Tomorrow ll be filling back with new oil. Oil was pentosin ffl-4. Any idea what could be the issue.
Thank you for any help
