1 - 11 of 11 Posts
Banned
im assuming 335 MPSS? Ive got pictures of when my car had advan gt's lowered on kw v3 with 315 r888
Banned
yes sir, will be going to 325 or 315 r888 after I wear these Michelins out. Seems that the mpss sidewalls are really wider than the r888s
they are indeed. sounds like a good plan. 325 r888r's wouldnt be a bad replacement for those MPSS
285/335 MPSS . Small drop with H&R springs
Sent from my SM-G955U using Tapatalk
Phangstaz,
Can you take a pic of the poke for the rear tires? Also, is there any poke up front? I assume the front are +35?
Sure!
First pic is lowered 1 inch on sleeves, other pics are stock height for comparison. The fronts are +35 and they don't poke even at stock height
Thanks so much for those pics. Perfect angles so I can see exactly what it looks like with the offsets and tires I am looking at. I’m looking at staying stock height so that helps a ton that you show both stock height and lowered. Did lowering it and changing the camber help a little?
Thanks so much for those pics. Perfect angles so I can see exactly what it looks like with the offsets and tires I am looking at. I'm looking at staying stock height so that helps a ton that you show both stock height and lowered. Did lowering it and changing the camber help a little?
No problem. Lowering definitely helped, my rear camber is actually -2.4 right now which is OK-ish for street driving and I would say it is flush.
Sure!
Hello, could you please post this pic again, or at least the pic of the car lowered on Neko sleeves? My GT-R is currently stock height with MPSS the same size(the rear pokes a bit) and im getting the Neko sleeves soon. Thank you.
1 - 11 of 11 Posts
