1 - 1 of 1 Posts
If you're an enthusiast/hobbyist of some sort you can definitely agree that when the craving for MORE strikes the hunger doesn't leave until its fed. Back for more is a good client by the name of Jae who previously had our SPE900 kit installed on his GT-R.
This time around Jae wanted big power, making our SPE1000 package his upgrade choice. Jae resides in Korea where he takes his GT-R to the track on a normal basis. A random fact about Jae's SPE1000 build his final tune will be utilizing a 91 octane map; reason being that it's difficult to source race fuel in Korea.
SPE1000 kit includes:
SPE LONG BLOCK
  • SPE Spec Full Blue Print and Balanced Race Short Block
  • SPE Spec H Beam Connecting Rods with Carr Fasteners
  • SPE Spec Forged Pistons 95.5mm Bore
  • SPE Spec Nissan Main and Rod Bearings
  • SPE Spec Metal Head Gasket
  • SPE Spec Camshafts 256/264 Degree with 10.25/10.50mm Lift
  • SPE Spec Spark Plugs Heat Range 9
SPE Twin Turbo Kit
  • SPE TD06SH 20G Turbo x2 (SPE HYBRID) 950+ HP
  • SPE Spec Stainless Tubular Manifold
  • SPE Spec External Wastegate
  • SPE Spec 29R XL Intercooler (294x710x115mm core)
  • SPE Spec Aluminum Intercooler Pipe
  • SPE Spec Blow Off Valve + Charge Pipe
  • SPE Spec Cold Air Suction Pipe Kit
SPE FUEL SYSTEM
  • SPE Spec 1000CC Injectors
  • SPE Spec Dual 340LPH In Tank Fuel Pumps
  • SPE Spec Fuel Pressure Regulator and Fuel Gauge
COBB AcessPORT
  • SPE Custom Tune
  • Pump Gas Map
**In addition to what our SPE1000 kit comes with a few more upgrades were added to the list**
SPE Stage 1 transmission build
  • PPG 1ST GEAR UPGRADE
  • DODSON SPORTSMAN KIT
  • DODSON CIRCLIP 1&2
  • DODSON REUSABLE TRANSMISSION FILTER
  • DODSON GEAR LOCK
  • DODSON OIL PUMP UPGRADE
  • DODSON PISTON 1 & 2
  • HKS DCT FLUID
Extras Accessories
  • HKS Transmission oil pan
  • SPE custom oil catch can
  • Carbing coolant tank
  • Greddy carbon intercooler air duct
SPE stage 1 head package
  • Ferrera Complete Valavetrain
  • Port/polish
Titek titanium race exhaust V.1
SPE 90mm suction pipe kit
Greddy DCT cooler
Greddy intercooler carbon air duct
Titek carbon intake manifold cover
Titek carbon cooling panel
HKS EVC (SPE Custom carbon bezel for these mods)
HKS AFK (monitoring air/fuel ratio)
**NOTE exterior parts previously installed
  • Titek front lip
  • Titek side skirt
  • Titek rear wing
  • Titek hood ducts
  • Titek front grille
  • Titek fender grille
  • Swift sport springs
  • Ichiba spacers 15mm front 20mm rear
  • Titek race mid pipe
  • Titek race exhaust (version 1)
  • HKS EVC (SPE Custom carbon bezel for these mods)
  • HKS AFK (monitoring air/fuel ratio)
Overall this project process was real fun to work on. We're glad our customers like to build fast cars & put them to use at the track. Hopefully we'll get some time slip update's from Jae and his new Korean bound toy.
More images of this build can be found here: http://www.sp-power....enough-spe1000/
- Eugene @ SP Engineering
1 - 1 of 1 Posts
