They do not to the best of my knowledge. However, if you send the VIN to Shep, he may have some record of work on it. Visually, they do not look different unless a brace is added. But that won't indicate a clutch/basket or gear upgrade.
Stock engine can handle up to about 650wtq. Most prefer in the 620-630 range.If you are on stock engine internals I'd be hesitant to push a lot further. Rods go before gearbox as I recall.
As mentioned before. Can't visually see if trans is modified.need to open her up.
