We have finished making the T1R Prototype Turbo Outlet pipes. We have dynoed the outlet pipes vs T1R 90R exhaust, Voltage stabilizer and mid-pipe (down pipe). Here's the pic of the pipe :
T1R Turbo outlet pipe
- SUS316 76.3mm (3") pipe
- Processed with TIG welding
- comes with mechanic O2 simulator (no CEL)
- 10whp gains at peak / 29whp @ 6000rpm
- T1R weighs 4.32kg (9.5 lbs) vs stock 11.27 kg (24.8 lbs) **6.95kg (15.29 lbs) weight savings**
- Estimated Retail price $1050CAD approx. $795USD
- Releasing date : April 2009 !
The dyno test has been performed with Dynapak AWD dyno and stock was making 409whp. I have attached the dyno chart break down so you can see what power and torque that was making through out the rpm ranges. Dyno numbers are all SAE Corrected.
Regards,
Ben @ AJR
.jpg)
Regards,
Ben @ AJR
