Started up my 2012 tonight to go out for a short spin. I turned on my headlights and noticed that my center console wasn't lite up. All the controls still work, just no lights. Also realized that my rear tail lights were not illuminated when the headlights were on (brake lights still function). I figured it might be a blown fuse so I opened up the fuse box to find the "tail/illumi" 10amp fuse was blown. I changed the fuse with the spare 10amp and tested the headlights again to see if the rear would light up but again, same problem. Checked the fuse i just changed and it blew again immediately.
The only modifications ive done are LED's in the front corner markers, headlights, rear plate, interior doors, and dome lights. All of them still work except the rear plate. I did a visual inspection of the rear plate LED's/plugs and everything seems to be in order.
Could the LED's be the cause of the blown fuse? Has this happened to any one else?
I came inside to take a short break from this and did a search but nothing came up. Any help is appreciated.
