Hello,
I will try to describe as best I can, it happens randomly, and I cant never mimic it when I try. I just happened to be logging when this happened at this time.
It happened twice yesterday, one time right before I was going to log as well..
Anyways, I come to a full stop, and then I would press on the gas slightly to go, the car would go like a few feet, and then it would feel like the throttle just closed or was cut and nothing would happen (foot still pressing on the pedal same amount), only momentum is moving the car, and then a rubber band affect would kick in and the car would lurch forward and go (as long as I didnt let off the gas) about a second later.
No cel, no random lights on my dash nothing. Only happens when I come to a stop and then when I press on the gas to go, not flooring it, just regular go. Car drives fine before and after, does not do this when actually driving around, cruising, or WOT
I set a mark on the log shortly after this occurred, tuner said he didnt see anything odd, but the occurrence did happen. I highlighted where I think is where I Was at a stop sign up to the point where I hit mark, Should start around line 115, end at 615
Unsure what parameters to even look at to begin with :-/
+2+2 for capacity, stock trans, FBO E85 2014, if that matters
TIA
Edit updated with a recent one that happened earlier in the evening, I believe it happened around line 2350, I hit mark a little after it occurred.
I was at a stop light completely stopped.
It went green and I pressed on the gas
About 1/4 of the way into the intersection, it felt like the car either stalled or throttle just got cut, my foot stayed pressed on the gas, and then shortly after it went back to normal and the car just took off like the rubber band effect I had mentioned
TIA
