Hello guys,
New to this forum and need some major help. I just put on some ferrada wheels yesterday 20x10.5 +25 front 20x11.5 +15 rear wrapped in nitto nt555 g2 315/35/20 rear and 275/35/20 front. I drove it last night and the vdc blinked twice and went away then again twice and went away and car felt like it was in limp mode. The AWD light came on as well and I turned off and on the car and it went away. There were no more lights on at all after that. Drove today and while WOT from first gear it was major lag like it was trying to push but it wasn't. It was pushing from 8-10lbs boost back and forth until shifting into 2nd gear and going to 15lb boost and then doing the same lag like it's cutting off and on off and on until recline. 3rd + gears are all fine. I am thinking it's due to the tires? I hope I did not mess my tranny up. I don't know what to do. I was looking at tire diameter issues but can anyone help on this if they have experienced any major lag in 1st and 2nd gear to a point where you can feel the car go to 3k rpm to 4k rpm back down to 3k rpm then up again after putting on new tires and wheels? Will changing the rear tires to 295/35/20 fix it? Or is my tyranny messed up now? Thanks guys!!!
