i have a 2013 blue gtr with all bolt ons flex fuel all the goodies . i have dunlop all seasons as my car came with the cold package which means all seasons instead of summer. i have 15 mm spacers up front 30 in the back need the right setup on the stock rims I'm thinking of going with the r888 as i only drive my car on nice days in spring ,fall,summer this car has never been in raIN nor will it ever see rain PLEASE HELP sizes and some performance tire options other than the r888 thanks
If you only want options for summer tires then-
285/35-20 on front and rear OEM wheels, you can try your spacers or without spacers in front and use the 15mm spacers for the rears just for the clearance on the wider than OEM front tire size.
Otherwise 15 to 20mm front spacer and 20mm rear spacer is what many owners use with OEM wheels.
Extreme Summer tire (non runflat)- wears faster than Max Summer tire but gives good dry grip, treadwear 200. May be a little louder and firm riding than Michelin Pilot Super Sport.
see
http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=EP&sortValue=0&filter=y&width=285%2F&ratio=35&diameter=20&rearWidth=255%2F&rearRatio=40&rearDiameter=17
Hankook Ventus R-S3 version 2 $329 each, tirerack can be special ordered, currently on back order
BFG Rival $284 each closeout at tirerack (see
[email protected]) $70 master card offer on set of 4 tires purchased until 11/29/15
Max Summer tires
see
http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=MP&sortValue=0&filter=y&width=285%2F&ratio=35&diameter=20&rearWidth=255%2F&rearRatio=40&rearDiameter=17
Michelin Pilot Super Sport $359.36 in stock at tirerack.com, 300 treadwear. Good choice for street tire used for daily driving but still very good dry and good wet handling with comfort. Comes in OEM sizes and can fit wider than OEM rear tire on OEM rear wheel like 295/35-20 but costs more $408 each (K1 Ferrari spec tire).
No non runflat All season tires recommended. No Ultra High Performance Summer tires recommended.
