1 - 20 of 31 Posts
GTR-warlord
What's a good set of tires to invest in ?
Factory tires give too much road noise and suck in rainy /cold weather.
Looking for tires to kill the road noise and still get traction in good & bad weather , any suggestions ?
Are the toyo proxy r888 good to solve my issues ? Michelins ?
I won't get into the definition of an investment, however, R888's or MPSS are both great. R888's will offer more grip but last about half as long. MPSS is imo the perfect all around tire as it offers great grip, low noise, and I should be able to get 12-15k miles out of them. Which is a lot for me and a set of tires. People also use the P Zero. I don't like the way they look and imo the MPSS are the superior tire
I love the MPSS for sure, but they were out of stock when I went to order tires, so I went with Bridgestone Potenza RE070's and I love them!!! I will probably get the MPSS's next (just because I haven't had them on my GT-R yet....I have them on my tuned 2014 Audi S4 and you almost can't break them loose!!)!! But don't be afraid to try the Potenza's!! They are really awesome.
R.I.P. Paul Walker
Why not run stock sizes ? What's the difference in going up sizes ?
You'll get a wider surface area and the car will look more aggressive. I suggest just getting 285/35/20 for fronts and either the same for the rear, or 295/35/20 for the rear...or 335/30/20 for the rear. All 3 rear options will work for your 285/35/20 fronts. The MPSS's also are slightly smaller in width than stated. Normally you wouldn't think a 335 could be used on the stock rear wheels on a gtr..but plenty of people run the 285/35 for front and 335/30 for rear.
I personally have 285 35 20 in front and 295 35 20 in rear. Good luck.
MPSS 285/35/20 and 335/30/20 on Advan GTs... These tires were a huge step above the Nitto NT05 tires that I had before.
Sent from Galaxy NOTE 5
MPSS gets my vote, great performance and better than average wear.
stock rims can handle 335/30/20 for the rear? seems quite wide
MPSS are great tires, but here in Pittsburgh I never got more than 10,000 miles.
I was a bit unsure of this size too for stock wheel, but after having 335's installed, I'm pretty happy. As far as effective increase contact patch, it's questionable. Under hard acceleration they still break loose, can't tell if they truly provide more traction over stock sized tires. Ride is softer for sure.
interesting. I found a set of rear 335/30/20 Michelin Pilot Sport ps2 for $300 with 90% tread left. Was thinking of getting it.
1 - 20 of 31 Posts
