I'm not to GTR's and new to this forum but have seen some very helpful posts on here. I have an '09 JDM, which I bought in sept'13 with 22000 miles. It was stock when I bought it and it has now done 28000 miles. I have never racked it or launched it but I have not doubt it has had both done (probably lots) prior to me purchasing it. It has always had a prominent 'binding' noise (most noticeable in low gears at low speeds - probably due to reduced cabin noise) which I have been told is one of the many 'normal' noises. I changed the bell housing but this did not help significantly. After its 24000 mile service (including TM oil change) I noticed a 'squawk' when changing from second to third at 4000-6000 revs and maybe a slight delay in the change. I had Litchfield look at the gearbox; they could not find anything obvious but replaced the cir clips, solenoid and ends?, as well as the 3rd gear and synchro. Unfortunately the noise persisted. They suspected it may be noise from the clutch (due to play in a part, the name of which I can't remember) - maybe the same noise as the 'binding' but at a higher frequency (maybe even resonant frequency?). They upgraded by TM software (2010?) but this made no difference. They also played with the clutch settings but this did not significantly effect the noise.
More recently I have noticed that the delay when changing 2nd to 3rd is more pronounced and on 2 occasions I have noticed changing into 4th is abnormal. This happens when I am accelerating moderately (75%). The change to 3rd is a bit slow and then when changing into 4th there is a loss of power and then 4th gear clunks into place with a jolt.
On another occasion it was as if there was no gear selected briefly (when changing 3rd to 4th), the engine revved, I reflexly took my foot off the gas and then 4th gear clunked into place with a jolt.
I have never seen any warning lights regarding the transmission and the car seems to drive fine afterwards. It has happened in auto and manual.
I wonder if this could be a clutch issue - maybe having difficulty binding/releasing?
Should I get a new clutch? Any recommendations for a clutch which has less 'binding' noise and room for modest power upgrades? Any other suggestions and opinions welcomed.
