Can I switch from twin walbro 458 in stock bucket to the tripple aem in a radium holder.
I have 3 of the AEM's in a radium hanger making 800 whp on stock fpr and rails. I left 1 on factory wiring and hardwired the secondaries. id1300cc injectors. the trick is having the secondary pumps come on at the right time. any competent tuner should be able to handle that. I later went radium FPR, rails and bigger lines but only to make space for more power laterwould three AEM pumps be to much for the stock FPR and lines? i am about 800whp on E85.
its not about total flow, its about if your hardwired, if on one or both pumps, what you want to do in the future. If your a gambler, you can change out the pump config and check your trims. Don't forget the check valve. Radium underplays this heavily and the car takes forever to prime without it. I learned this the hard way. GLThe difference in total flow is 60lph. 450 x 2 =900 - 960 (320 x 3) = 60lph
I have to go back into the tank my scavenge pump is not working. Just wanting to go to something better than the stock bucket.
60lph more fuel requires a tune?
How are you going to wire the 2 AEMs as the primary? I've never heard of anybody running 2 pumps like that. I have the complete Radium Fuel Setup and I've done various combinations of pumps to find the right ones. I have another thread discussing the issues with the Radium fuel system. However, I think you're best bet is to get the AEM as the primary so the OEM FPCM can still use the logic from the ecu so you can retain the stages of 33% 66% 99%. It'll also keep the heat out of your fuel when you're idling. Then for the secondary, I would just get a Brushless pump. That combo of the AEM and Ti Auto BK1001 brushless setup is good for over 1100whp.My current setup is both pumps are hardwired. Stock wiring for trigger wire.
I was planning to run two pumps for primary and one for secondary.
Do you see any problems with this setup?
Thank you Sonicboom for the quick response.Low 700 whp
