My rear R888s are unevenly worn, fronts are good. Is it possible to remove the rear tires from the wheels and turn them around so i can use them some more or will this f-ck something up?
I did that to a set of uneven camber worn R888s about 6 months ago. Works fine. Will howl a lot the first 300 miles but then go back to normal noise levels.
The tires can be flipped. They will need to be dismounted from the wheel and then flipped. You will get some more life since your inside wall will now becomeyour outside wall.
