1 - 9 of 9 Posts
Greyzilla activist
Just an update at the track this past weekend amb temp low 70
Engine oil < 200 f after Descartes fool's engine oil cooler
Coolant 210 Koyo radiator
Tranny 240 HKS cooler
I ran the entire day without over heating... Best I've done ever
I usually quite after 2-3 sessions
Glad to hear it!
Curious do you have a before/after temp breakdown of each thing (engine oil, coolant, tranny cooler)? Or did you do them all at the same time?
I am especially curious as to how much the radiator upgrade helped but wonder when it was done in proximity to the other cooling upgrades.
Greyzilla activist
I did tranny and radiator first and both temp was under good control, but engine oil will still be high
After engine oil cooler, all under good control.
Glad my oil cooler mod worked for you too. It's really nice to be able to run all day at the track without overheating anything. Well, except the brakes;-)
I'm running stock rad and I did get a coolant overheat warning once last year, but only once. Other than that, I was able to run flat out the whole year. HKS tranny cooler as well.
May I ask what oil cooler mod that is?
Thanks
What was the ambient temp that day? Kind of dissapointing the trans cooler still doesn't keep it under 238F or whatever it is to use the longer fluid change interval.
Greyzilla activist
Dude , use upgraded oil then good to 260
Nice results dob! It's so satisfying after all the work we put in, when the car will finally run cool enough to enjoy it!
1 - 9 of 9 Posts
