1 - 11 of 11 Posts
The download for it can be found here. Thanks to Ben Linney for the dopbox link:
https://www.dropbox.com/s/bltievmu8q4g8dm/AWD Nissan GTR 2_0_1_0 Setup.rar?dl=0&fbclid=IwAR3oXIvCzOGMDznFPW66PoHfcrN4swqliXw4P6JpIWemvlHSTUzC-v-0fSs
I asked Ben about details about the new V2 software and he mentioned "It has high map resolution, data logging and you can differentiate wheel slip and brake lock a little easier. You will have the option of seeing it as it is now, or being able to show as negative slip."
Can someone please explain me how "slip axle" tables work? Say if the rear spins with 20% vs the front axle, and say you have 50 in that particular cell in the main table and 40 in the cell in the >20 slip table, it add 40% to the main table of 50, which in total will be 70% clamp to the fwd clutch?
Do you have an AWD controller, and didn't you have an ETS problem in another thread? Before he passed, I had a chat with Doug from WGP and he did not recommend the KAPS AWD controllers because they cause ETS issues. Not sure if this applies to you, but FYI...
Yes I have an awd controller, but it seems my ETS was gone before I got the controller... I only used it a little to try to throubleshoot why I got so much rearwheel spin when launching. I think it is like Jacks explained in his Youtube video that some of the maps that comes with the controller have to much lock´ when not needed... One of the default maps have 100% clamp all the way from 0 to max speed... That puts unneccesary stress/friction to the ETS and tires.
yes I remember that Doug commented on my post that you will be looking for an ETS next, and he was right:) But I think my ETS already was weak/destroyed...
One thing I've found is that the firmware on V2 puts the coil power as default of 0.
1 - 11 of 11 Posts
