I am in the process of building a forged shortblock. My measurements came out very strange for the cylinder bores. Wondering if anyone has seen this happen?
My block is stamped 222222. 17k miles, perfect crosshatch.
According to the service manual my bore sizes should be 95.51-95.52mm. However my bore gauge read 95.55-95.57mm on all bores. Yes I triple checked. I thought my cylinder liners were worn out BUT…
Even stranger is that my stock pistons measured 95.52-95.53mm which is perfect for the stock piston clearance of 0.03mm!
Although all measurements came out bigger than than the service data, the clearance is still spot on for stock components.
However with forged Mahle drop-in pistons, the piston to wall clearance becomes too big, 0.1-0.12mm of clearance.
Something is wrong with my shortblock in a very strange way.
Should I drysleeve the block? Or custom order bigger pistons?
